Dual or two factor Authentication
dames
Post by dames » Wed Mar 17, 2021 12:09 am
Is it possible to require two of the authentication methods simultaneously?
I would like to require both a client certificate and a username/ password to authenticate.
i have explored and experimented, but I cannot see how to do this.
thank you in advance.
nobody12
Re: Dual or two factor Authentication
Post by nobody12 » Wed Mar 17, 2021 3:28 pm
You could setup authentication through radius with motp.
I made a test and did setup motp with sucess. (motp requires a password/pin of the user plus a generated otp by an motp password generator (usb stick/mobile phone) which is tied to the time plus an initial seed). For me this is a two factor authentication.
But this is not certificate plus username/password.
dames
Post by dames » Wed Mar 17, 2021 5:34 pm
Thank you
that sounds like an excellent solution, however I am unfamiliar with motp.
I'll look into it as a possible solution.
nobody12
Post by nobody12 » Wed Mar 17, 2021 5:49 pm
There is an old but working and easy to install solution for this (which I used):
https://github.com/MOTP-AS/MOTP-AS/blob/master/INSTALL
followup: The code for this is based on an "old" php version. If you want to run this on newer PHP without manually patching the code, there is an adapter availiable as a php include:
https://github.com/rubo77/php-mysql-fix ... ql.inc.php
motp generators an information about motp:
http://motp.sourceforge.net/
dames
Post by dames » Fri Mar 26, 2021 1:44 am
thank you very much. i'll check this out.
