individual servers to bridge conversion
blazer1992
Post by blazer1992 » Sat Mar 20, 2021 3:35 pm
I have 4 sites that I have installed SoftEther Server at so our users can login in to access the local resources. All sites are running SecureNAT to get a different IP for the connecting client because of lack of IP addresses. Local bridge is also disabled. I would like to convert 3 sites to bridges and have it link back to our main site. My question is do I have to uninstall the server software and reinstall the bridge version? Also if my users still want to access local resources at a particular site, do they / can they still vpn into that site or will they go to the main site now and then go over the site-to-site? Any help or thoughts on this would be greatly appreciated.
Thanks
centeredki69
Re: individual servers to bridge conversion
Post by centeredki69 » Mon Mar 22, 2021 10:32 am
You do NOT need to install the "SE-Bridge Software" which it a stripped down version of the "SE-Server software". The "SE-Bridge" only allows outbound "Cassade" connections & "Local Bridge" so clients would not be able to direct connect to these location if needed.
