Can I change my DNS off of google?
czpy
Post by czpy » Tue Mar 30, 2021 3:04 pm
As far as I can see, softether vpn defaults to Google DNS when using the openvpn clone feature, is there an option where I can change this to my standard system resolvers? I could not locate it on the softether vpn server panel.
centeredki69
Re: Can I change my DNS off of google?
Post by centeredki69 » Thu Apr 01, 2021 4:26 pm
The DNS servers the VPN clients use are assigned by the DHCP server (unless they are statically set on the NIC). If you are using the "local Bridge" feature they would be set on the local DHCP server (most likely the Router the SE-Server host is connected to). If you are using the "SecureNAT" feature the DNS server can be changed under "SecureNAT Configuration"
