Can't connect through azurevpn
hasanomar1992
Post by hasanomar1992 » Sat Apr 03, 2021 11:31 am
Kindly assist me, I have installed VPN server and it's working properly while connecting from LAN but, if I connect through VPN Azure hostname. it's not working. kindly assist.
sky59
Re: Can't connect through azurevpn
Post by sky59 » Sat Apr 03, 2021 12:55 pm
if your server is connected to the internet over very complicated network (like I experience in company) then it does not work.
try to use USB stick with SIM card for server- it must work for Azure you do not need public IP
eddiewu
Post by eddiewu » Sat Apr 03, 2021 3:41 pm
Open Windows SoftEther Server manager, connect to your server, click VPN azure settings.
What is the status shown in the lower left corner?
hasanomar1992
Post by hasanomar1992 » Sat Apr 03, 2021 5:30 pm
It is showing connected. maybe the azure working only for special vpn type like SSTP . not for all types.
sky59
Post by sky59 » Sat Apr 03, 2021 5:44 pm
What are you trying to solve? I have explained the problem already.
Or you try to find lost keys during the night where there is a public light but not where you lost the keys?
hasanomar1992
Post by hasanomar1992 » Sat Apr 03, 2021 5:56 pm
I'm trying to resolve my problem. I want to use softether vpn behind the firewall using azure. when I made client by windows, it's connected but when I tried to connect by my android using MS-SSTP app. it's showing SSL handshake failed.
eddiewu
Post by eddiewu » Sun Apr 04, 2021 1:33 am
Can you post the error log? The information you have provided is too limited.
Also you mentioned that you can connect from Windows SSTP. Was the connection made to vpnazure address or the server's real address?
Before knowing more information, I guess the problem could be from:
1. DNS issue (check the error log)
2. MS-SSTP app issue (try connecting from Windows client over mobile tethering)
