access list to restrict internet access
I setup 3 access lists in a virtual hub to restrict vpn client to access the internet. all client only can access 10.10.x.x and 10.128.x.x network. With the 3rd list. I can't get the IP address from dhcp server when I connect to the vpn server.
Re: access list to restrict internet access
I have the solution.
setup a NAT hub, no bridge, use DHCP to assign IP address to all vpn client without the gateway address. add all network address which allow vpn client to access in the " Edit the static routing table to push"
But I still don't know how to access list to restrict vpn client to access internet from vpn server side. :-)
