refer to the info:
IP packets that didn't match any access list items can be passed. How can I set only 192.168.1.x, 192.168.2.x and 192.168.3.x can be reached all other network will be rejected to access?
This access list concept is a little bit different with other firewall rule. Is there any document can explain this in detail?
How to use the access list
Re: How to use the access list
Hi
As far as I know, there is only one well-documented document on this feature, which is the following.
3.5.10 and 3.5.11 in SEVPN Server Manual : https://www.softether.org/4-docs/1-manu ... y_Features
Also, if you want to restrict IP access, please read 3.5.11 of this document.
I hope this is enough information for you.
