I have a small vpn at home office
It was working fine for last two years . I am using vnat and snat, on windows home 64 bit.
Now the problem is that I can get connected to VPN and get a IP address 192.168.40.100
and my Router is 192.168.1.1
I can ping the router , and I can ping yahoo.com
however I am unable to communicate with any lan computers 192.168.9.10. strange thing is that when I switch to local bridge I can ping to other vpn users who get the ip from the router dhcp 192.168.9.1 .
Please help , the problem is same whether I use a local bridge or snat vnat. can not communicate with lan physical computer
Help needed urgently
sky59
Re: Help needed urgently
How you can get IP address 192.168.40.100 from Router 192.168.1.1 ?
Have you changed something?
Do you have L3 bridge between the subnets x.x.9.x and x.x.40.x ? are they physically apart from each other?
Has the internet infrastructure been changed? How you connect to the internet?
you need to describe problem and your installation in much better way - the best to make picture, sketch
smallvpn
Thanks for the reply, and tips
further investigation resulting in finding the the target computer was take to office from home and it joined the office network, this was for few hours and I did not find about it. the target computer was blocking all the trafiic thinking it was a hostile network.
the 192.168.40 is the dhcp from secure nat.
192.168.9.1 is the lan the physical adapater is . sorry for the confusion, i should have been more detailed
Finally resolved.
Finally resolved.
