If you are using OpenVPN, the server sends routing recommendations to change the default gateway, which the client respects and apply these rules to the routing table.
If you want to ignore these rules and/or define your own routes, see this openVPN guide:
https://community.openvpn.net/openvpn/w ... ectGateway
After that you can push any route to any gateway using the --route directive:
https://openvpn.net/index.php/open-sour ... npage.html
Cheers
access to lan but not use lan intenet
moatazelmasry
Re: access to lan but not use lan intenet
Please increase metric of virtual NIC.
