Help
rogesh
Help
Post by rogesh » Fri Apr 23, 2021 6:15 am
Hello there
I'm utilizing the Packetix VPN worker on ubuntu running on VPS.
I have an issue when I empower secure NAT, I see a high burden on CPU by the VPN worker and customers' speed will be diminished.
I don't utilize any nearby extensions, and worker correspondence is straightforwardly through eth0.
What's the issue?
khosoya
Re: Help
Post by khosoya » Fri Apr 23, 2021 1:16 pm
You mention that you are using a VPS, but is that VPS powerful enough?
To get a good answer, write down the machine specs, logs, etc.., that would be involved.
And I found a similar problem (unstable behavior when using SecureNAT) on the JP forum.
In this case, they said it was fixed by deleting the local bridge settings that were not used. Just FYI.
Simillar Problem: https://www.vpnusers.com/viewtopic.php?f=15&t=66563
Regards
khosoya
