SoftEther supports both protocols. You just have to specify on the client side which protocol you want to use, for example in OpenVPN client configuration:
proto udp
Best
Can one switch the default SoftEther TCP protocol to UDP?
moatazelmasry
Re: Can one switch the default SoftEther TCP protocol to UDP
Please add '/' after destination host name.
