Unable to use softether vpn server
Lethal
Post by Lethal » Mon May 03, 2021 9:07 pm
I setup a vpn server with softether Server Manager and was able to connect to it from a laptop using a phones hotspot connection. It worked and I was able to connect to a Minecraft Alan server. However it doesn't seem to work on anyone else's internet connection. Multible people have tried to connect to it and none have got it to fully work yet. They are able to connect to the VPN, their IP changes, their internet works, they can even connect to my router page, however they cannon connect to the Miencraft LAN server. It is not a problem with Minecraft, it works on my laptop with the VPN. Everyone is using windows 10. I have no idea what could be causing this as far as I can tell everything between the laptop and their pc is the same but it does not work. I have also tried disabling firewalls in windows and the router on both the client and the server.
