We are struggling with a weird issue when the Windows Softether client will not get the gateway ARP for up to 10 min
We were able to prove that Windows 10 version 1809 and lower works fine, Windows 10 version 20H2 and windows 8.1 does not
We tried different versions of the client - with no success
Softether server is running on Linux and we tried V4.34 build 9744 , V4.32 build 9731 and V4.29 build 9806
Any help / suggestions will be VERY appreciated
ARP issues with newer version of Windows OS
khosoya
Re: ARP issues with newer version of Windows OS
HI,
This is strange. I've never had a problem with ARP in my deployment.
Could you describe more what 'gateway ARP' means in this question?
FYI, You might try disabling the NAT Traversal and UDP Acceleration features. These features can cause strange problems in some environments.
