Load Balance and High Availability
atm1989
I have a cluster setup with 1 controller and 2 member server. Each member server has a setting of 50 for the standard ratio in the cluster. But I only see one member server providing services at a time. So not sure how load balancing works. Also, lately the active member would stop working and the standby member server becomes the active one. This has happened on multiple occasions. Is there a log that I could look to see what is happening?
