SecureNat
INFO2021
SecureNat
Post by INFO2021 » Sun May 16, 2021 9:48 am
hi, I have installed softether vpn client and after a week noticed that I see my IP address and another internal address as securenat.
it shows securenet-dac562eecd3c. even if I disable the vpn client it still shows.
three questions:
1. I didn't install securenat - how could it be activated automatically?
2. I noticed another folder that was created in c:\program files\softether vpn client\ called security_log that wasn't there when I installed the vpn client.
3. How can I tell if it's dangerous or not, can there be a hacker on my network using softether vpn?
thanks in advance.
flygun
Re: SecureNat
Post by flygun » Wed May 19, 2021 3:16 am
did you connect to your own SoftEther Server? or connect to an unknow server?
