XAMPP + Softether VPN (Port 443 Blocking)
petrifiedw00d
Post by petrifiedw00d » Mon May 17, 2021 12:03 pm
Hello everyone! Quick question about port 443, I am trying to setup a web server using XAMPP and setup a VPN where users can connect to my network and then they should be able to access my website that is running through my localhost however, when I do this, the port 443 in XAMPP is being blocked as it was being used by Softether VPN. Is there a way around this or any configuration that I need to do for users to access the website through port 443?
Thank you everyone!
eddiewu
Re: XAMPP + Softether VPN (Port 443 Blocking)
Post by eddiewu » Tue May 18, 2021 5:27 am
Softether server can listen on any port you specify. Just remove 443 from the config.
petrifiedw00d
Post by petrifiedw00d » Tue May 18, 2021 11:35 am
Hey Eddie thanks! That's what I did, port 443 on SoftEther was stopped and XAMPP was able to run smoothly and my PC (the server) can access my local website, however, the client PC can't.
eddiewu
Post by eddiewu » Tue May 18, 2021 11:42 am
What's your server environment?
What IP is XAMPP listening at?
What IP does the client get from the VPN?
