New sofether setup: connect, disconnect: error 13
Locked
nobody12
Post by nobody12 » Thu May 20, 2021 7:03 pm
I have setup several Softether systems in the past, and everything went smooth. Not this time.
Client: windows 10, Connected with wifi to the internet.
Installed Softether client. VPN Adapter installed automatically with the wizard. Imported VPN Profile.
VPN connection started, IP address aquired. Immediately a disconnect happend with the error 13. Reconnect wont make it better.
I fixed it by setting the VPN adapters metric. It was set not to automatic but to 1. The Wifi adapter was set to automatic metric.
I changed the VPN adapters metric to 100.
Now the VPN works.
What happend here? I would expect the VPN adapter will have an "automatic" metric when the client is installed.
davidebeatrici
Re: New sofether setup: connect, disconnect: error 13
Post by davidebeatrici » Thu Jun 24, 2021 8:43 am
Fixed in 5.02.5180.
Locked
