Double Connections
SoftEtherUser10
Double Connections
Post by SoftEtherUser10 » Thu May 20, 2021 10:20 pm
I am having issues with connecting to my SoftEther. I had no problem connecting before but now I get error code 1. I been working with the IT of the office where my computer is and was told there is another company that uses SoftEther to connect on another computer.
My question is, can two computers have SoftEther on them and can both be connected to? I was told no, but it does not make sense to me.
flygun
Re: Double Connections
Post by flygun » Fri May 21, 2021 1:52 am
yes, your can. you can ask a different "listen port" to another computer from your IT officer.
or you can use "yourregistername.vpnazure.net" as a relay server event your IT officer don't like to give you a port.
SoftEtherUser10
Post by SoftEtherUser10 » Fri May 21, 2021 9:53 pm
Is the VPNAzure as reliable, safe, and quick? What is the difference if you do not mind me asking.
