Since 5.0.2 Error Code 13 in client/server logs
Locked
VSofter
Post by VSofter » Wed May 26, 2021 11:53 am
Hi.
I'm using softether-vpnserver on Linux Mint 20.1 (based on Ubuntu 20.04.1).
Few days ago I updated to 5.0.2 and can't connect with Softether VPN Client (Windows 10) to Server: both writing error code 13 in logs.
I tried disabling firewalls, recreating virtual NICs, disabling UDP acceleration - nothing helps.
Could you please give some advice on how to resolve the problem?
nobody12
Re: Since 5.0.2 Error Code 13 in client/server logs
Post by nobody12 » Fri May 28, 2021 5:47 pm
Dont know if this matches, but the Error code is the same:
https://www.vpnusers.com/viewtopic.php?f=7&t=66826
doprdele
Post by doprdele » Sun May 30, 2021 6:42 pm
I can confirm that downgrading to version 5.01.9674 (git checkout 039cd8e) fix this for me.
After half-day struggle, almost river of tears and trying all possible configuration wizardry i came across this post and tried older version - fixed, working imediately.
My setup:
server - Orange pi zero (tried orange pi zero 2 also), Armbian (tried Ubuntu as well). Built from source, latest git clone.
client - Win 7, Softether client version 4.34
I do not see Error code 13 in server logs. I see only:
The session has been terminated. The statistical information is as follows: Total outgoing data size: 0 bytes, Total incoming data size: 0 bytes.
But i see Error 13 on the client side.
davidebeatrici
Post by davidebeatrici » Thu Jun 24, 2021 8:43 am
Fixed in 5.02.5180.
Locked
