hi, i have a running softether vpn server, with securenat and DHCP configured in an AWS EC2 client, works perfectly. until i realise a group of computers unable to get IP address from the configured securenat dhcp server, end up with a 169.x.x.x IP address which means routing, etc will fail.
the common pattern of those computers, are their ISP is using ipv6, does anyone knows how to solve this issue? thanks
unable to get DHCP IP address from SecureNat config
desmondcs
eddiewu
Re: unable to get DHCP IP address from SecureNat config
IPv6 links do not have anything to do with the DHCP inside the tunnel. There must be something else causing the issue.
