This is (hopefully...) as a replacement for OpenVPN, which is, frankly IMO - a nuisance & has been used for remote accesses to the other PCs on the small LAN there, over 100 miles from where I live.
I added a Softether server there remotely - which appears to be working just fine, but getting the Softether client to work under Ubuntu is not working for me...yet, so I cannot connect to that PC or any other via Softether yet.
The best info I found for making the connection for remote access is rather long & complicated:
https://www.aspkin.com/forums/ip-address/109664-solved-softether-client-linux-tutoral.htmlCode: Select all
https://www.rapidvpn.com/setup-vpn-softether-ubuntuIf so, might you have any really helpful pointers or education about it to share, please ??
Thanks.
