After upgrading to version 5.02 Build 9675, OpenVPN clients cannot connect to udp port1194.
I run vpncmd to see what was the matter and found the following:
VPN Server>ServerInfoGet
ServerInfoGet command - Get server information
Item |Value
Product Name |SoftEther VPN Server Developer Edition (64 bit) (Open Source)
Version |Version 5.02 Build 9675 (English)
Build |Compiled 2021/07/01 20:37:50 by nobody at FreeBSD:12:2:amd64-default-daily-job-06
Host Name |test.example.com
Server Type |Standalone Server
Type of Operating System |BSD System
Product Name of Operating System|FreeBSD
Operating System Vendor |FreeBSD
Operating System Version |12.2-RELEASE-p7
Type of OS Kernel |UNIX
Version of OS Kernel |FreeBSD 12.2-RELEASE-p7 GENERIC
VPN Server>OpenVpnGet
"OpenVpnGet": Command not found.
You can use the HELP command to view a list of the available commands.
VPN Server>Also, in confuguration file is no one information about OpenVPN config!
I rollback to version 5.01 - in this version all okay with OpenVPN:
Item |Value
Version |Version 5.01 Build 9674 (English)
Build |Compiled 2021/06/06 22:57:25 by root at 122amd64-quarterly-job-04
OpenVpnGet command - Get the Current Settings of OpenVPN Clone Server Function
Item |Value
OpenVPN Clone Server Enabled|Yes
UDP Port List |1194
VPN Server>
