I am running Softether VPN on a Windows machine. I can connect to the server from the Softether client without a problem.
I am struggling to connect using the OpenVPN client.
I'm getting the connection timeout error in the client.
Softether Server version 4.34 Build 9745.
Does anyone have any clues?
Appreciate your help
OpenVPN Clone Server
Re: OpenVPN Clone Server
up please, i have the same issue. I can't connect with openvpn client to the softether VPN, with a time out error
same problem here !!!
Any news on this case?
No problem here.
Server 4.38 Build
Client https://openvpn.net/downloads/openvpn-c ... indows.msi
You can either connect to 443 or 1194 according to the configuration of the client settings.
Do not forget to place certificate in ovpn config-file.
See https://www.brainfart.sg/index.php/2012 ... pn-config/
You can also set up a lab using virtualbox. But do not use "Bridged networking" on NIC on VMs involed in the VPN as this causes trouble. Use "Internal networking" instead. So you are able to build a fully working SoftEther lab. Here you can validate your settings.
No problem here.
Server 4.38 Build
