use softethervpn go back to china
terrence
Post by terrence » Mon Jul 12, 2021 2:56 am
hello every, I encountered a problem recently. The situation is like this:
When I connected to the VPN for the first time, the connection was normal. But after a few minutes, when I disconnect the current connection and wait to connect again, I cannot connect.
And after I checked, I found that the connected port is no longer available.
I tried many ports, and they were all closed immediately after using them once.
I want to ask, have any friends encountered this problem? Is it because the FW of China restricts softethervpn to allow no more access? Is there any way to solve this problem?
Bohdan
Re: use softethervpn go back to china
Post by Bohdan » Mon Jul 12, 2021 6:12 am
Hi, a similar problem of SE availability in China. No solution found (
terrence
Post by terrence » Mon Jul 12, 2021 9:57 am
Really bad news...
sky59
Post by sky59 » Mon Jul 12, 2021 12:08 pm
No internet in China
