SoftEther VPN use the Network % alot
saitama4853
Post by saitama4853 » Tue Jul 13, 2021 1:35 am
I don't know what is this problem. The SoftEther Client has Network Rate very high when I checked in Task Manager. This has not happened before. After turn off VPN, this rate back to normal so the SoftEther might be trying to download data but I don't know what is it? Please help me to check because it will take down the internet speed.
Here is the screenshot: https://prnt.sc/1anzakx
saitama4853
Re: SoftEther VPN use the Network % alot
Post by saitama4853 » Wed Jul 14, 2021 1:27 am
please help me :(
nobody12
Post by nobody12 » Sun Jul 18, 2021 8:14 pm
Unless you made a custom configuration, the Softether VPN will be the default gateway for the System after the connection is established. Even Windows updates will use the VPN.
From the Taskmanager open the performance tab, then start the resource Monitor. Then select Network, you then should be able to see which process consumes how many bandwidth of the vpn connection.
saitama4853
Post by saitama4853 » Mon Jul 19, 2021 1:29 am
Can you please help me to check? This is the screenshot: https://prnt.sc/1cvv88l
saitama4853
Post by saitama4853 » Mon Jul 19, 2021 1:30 am
nobody12
Post by nobody12 » Sat Jul 24, 2021 7:56 am
If the taskmanager and the resourcemonitor does not give you enough information, try out wireshark:
https://www.wireshark.org/
There is also ProcessMonitor and ProcessExplorer from the Microsoft Sysinternals Suite
