Hello! I am configuring a Mac Pro with 2 ethernet ports and trying to get the local bridge to work, but in the settings, there are no LAN adapters that appear. Restarted the computer several times but had no effect.
Tried to use Virtual NAT/DHCP server but could not access the local network with that.
Appreciate any ideas on what to do. Thank you!
[Solved] SoftEther in macOS not showing Ethernet adapter
butchm
butchm
Re: SoftEther in macOS not showing Ethernet adapter
Solved this by using:
sudo ./vpnserver start
