I was set up on this years ago, but changed PCs.
Not sure what goes in :
Host Name
Virtual Hub Name
using just VPN Client.
Connetion Settings Properties
effertzglarson
Re: Connetion Settings Properties
The VPN profile is already "Set as startup connection". you can check out in properties SIZE=1 jigsaw puzzle
dbwr
That was a useless reply to my question.
Doesn't matter - found a better vpn.
Terraterm
