Specify virtual hub with OpenVPN client and signed certificate authentication
jds_support
Post by jds_support » Thu Sep 09, 2021 8:51 am
I have successfully used the OpenVPN client to connect to a user in the DEFAULT virtual hub with signed certificate authentication however, I can't find a way to use the OpenVPN client to connect to a user in a different virtual hub using signed certificate authentication.
I know you can specify the virtual hub with username/password authentication, but is there a way to specify which virtual hub you want to use in the OpenVPN client when using certificate authentication?
