Hi everyone,
I have the following situation: I want to connect a Windows pc to a Softether server hosted externally. The issue is, I don't have admin privilleges on this Windows machine.
Is it possible to install the Softether Client onto something like a Raspberry Pi, and then connect this RPI to the Windows pc with either an ethernet cable, or a usb cable. This way the Raspberry Pi would be visible as a network device (like WiFi and LAN devices) and I could connect to that.
Thanks in advance!
Raspberry PI with Softether as network device windows
underlyingglitch
eddiewu
Re: Raspberry PI with Softether as network device windows
Is there any reason that you don't use a native client on Windows? L2TP and SSTP can do the job.
