Hello all,
I would like to connect to a VPN Hub without using its Internet connection, so that Internet request go through the Clients IP-Address.
How can I do this?
Thanks
Connect to VPN Hub without using its Internet connection
dbeh
nobody12
Re: Connect to VPN Hub without using its Internet connection
You mean: Traffic to the internet should not go through the VPN? And you use Windows 10?
Then: in the properties of the VPN adapter, open then settings for TCPv4, click advanced, uncheck automatic metric if checked, enter a higher value then any other network adapter is using, for example a value of 500 will be sufficient.
If still traffic for the internet goes through the VPN: In the properties of the VPN connection in the softether client: advanced option: tick "no adjustment of routing table"
