I have installed softether vpn server in the service mode. I created a server and successfully connected to it with client side. Then I restart the pc that is running server side to test if it is automatically starts. Everything was fine. I could connect with client to the server. But the problem is I cannot access to my server setting(to add more users or change settings). When I open the softether vpn server program and try to connect it errors: “several vpn server on the same IP …” how can I access to my server setting again? I appreciate any help.
Cannot access my server settings after reboot.
Solish7
