Number of concurrent TCP/IP connections
Jace-99
I have a VPN server and remote Bridge, Lan 2 Lan. I see in the literature, 4.4.12 Number of TCP/IP Connections for VPN Session Communications, https://www.softether.org/4-docs/1-manu ... VPN_Server,there are advanced settings to allow the 'number of TCP/IP connections' to be increased. I cannot find these settings. IS this something I can edit in my set up?
nobody12
Re: Number of concurrent TCP/IP connections
You find this in the Client profile, in the advanced properties of the settings
