Hardware (routers) with SE client or server?
nobody12
Post by nobody12 » Mon Nov 29, 2021 6:56 pm
I found, that older (currently unavailable) versions of ubiquiti routers have an option to install SE, also There are routers from a company gl-inet where you can install SE.
Is there anything else whe SE is an option? I am looking for something which is proved working. Having an inexpensive device which will need a large amount of time to get it up and running is not an acceptable choice.
SE should install on most devices running openWRT. But what is a good choice?
TIA
Re: Hardware (routers) with SE client or server?
Post by solo » Wed Dec 01, 2021 9:33 pm
I have a couple of GL.iNet routers but I do not see a native SE option. As you mentioned, when their firmware is replaced with OpenWrt, SE can be installed. I confirm that SE on a cheap GL-MT300N-V2 works fine and wrote about it on this forum here
viewtopic.php?f=7&t=66579#p92719
nobody12
Post by nobody12 » Sat Dec 04, 2021 9:17 am
Thank you Solo.
In your post you wrote you tried openWrt for testing. But have you had this running for a few month with SE running?
Post by solo » Sat Dec 04, 2021 12:08 pm
I still use it since the post in Feb 21, but not constantly. I modified the GL.iNet SE server for a field support device which a technician connects to a customer's router/LAN and then I can remotely access it on Layer 2 via either VPN Azure or 2 cascades (for backup/reliability) to our local SE servers. It works flawlessly, but again, this is not a 24/7 SE application.
nobody12
Post by nobody12 » Sat Dec 04, 2021 12:23 pm
Thank you. Sounds good.
Good enough to buy a test unit and try myself
