Logs are not generating in the log file :( . PLEASE HELP
Locked
nitinpal07
Post by nitinpal07 » Wed Dec 29, 2021 10:27 am
In my VPN server log file is created every day when the connection is made but logs are not generating only the shown below text is getting generated in the log file
2021-12-29 14:02:25.611 SoftEther VPN Server Version 4.38 Build 9760 (English)
2021-12-29 14:02:25.611 Compiled 2021/08/17 22:32:49 by buildsan at crosswin
2021-12-29 14:02:25.611 Log Messages are written with UTF-8 Encoding Format.
2021-12-29 14:02:25.611 The SoftEther VPN Server has been started.
2021-12-29 14:02:25.611 IPsec Module: The IPsec ver 2.0 (ISAKMP/IKEv1) processing module is started.
2021-12-29 14:02:25.621 OpenVPN Module: The OpenVPN Server Module is starting.
2021-12-29 14:02:25.621 Loading the configuration file.
2021-12-29 14:02:27.942 Monitoring the directory "/usr/local/vpnserver". If the amount of available free disk space becomes less than 100.00 MBytes, the backup files for log files and configurations that are saved on the sub-directories of this directory will be automatically deleted in the order of oldest first. The amount of free disk space that determines when to start deletion can be modified by changing the "AutoDeleteCheckDiskFreeSpaceMin" item in the configuration file.
Please HELP ME!!!!!!!!!!!!!!!
Locked
