FEATURE REQUEST
mphayesuk
FEATURE REQUEST
Post by mphayesuk » Thu Feb 10, 2022 9:18 am
Hi all, I am hoping that this makes its way to teh product/dev team.
What would be nice is on the VPN Client if the RADIUS authentication is selected there is an option to force a passowrd prompt when connecting to the VPN.
The reason is, I use MFA/2FA over RADIUS and as such the password will be different every time the user logs on, so storing the password and having auto-logon/auto-connect means that the first authentication will always fail.
No matter what I select this always happens, the VPN client tries to auto-connect, even with reconnects option turned off. I have applied a small workaround which is to increase the timeout between reconnects and increased the fail count on my MFA, but these are not good fixes for security reasons.
Many thanks
