Don't route general internet traffic
rp-approvedfood
Post by rp-approvedfood » Wed Mar 23, 2022 1:35 pm
Hello
As per the title, I would like to know how to configure SE so that when a connection is established, the client does NOT send its general internet traffic down the VPN.
On the old Windows VPN client, it was as straight forward as unticking a box in the Network adapter properties > Advanced etc but I can't seem to find an option either in the SE client or OpenVPN client (which my Mac users use).
Thanks for any suggestions or help, I have consulted the almighty Google but there wasn't anything that seemed relevant to my configuration.
nobody12
Re: Don't route general internet traffic
Post by nobody12 » Wed Mar 23, 2022 6:33 pm
you have the following options when using windos 10 with the SE native client:
if you use the secure-nat feature, in the dhcp options of the secure-nat subnet, dont set a default route.
if you use the default settings of Softether:
open the network adapter properties on the client, tcp-ipv4, anvanced settings:
make sure that the automatic metric checkbox is not selected. Enter a large value like 500 as the metric value
in the settings of the VPN client: advanced settings: check "no adjustment of routing table"
Regarding openVPN:
you have to build an openVPN config file (for the client) which will not set a default route:
like:
route-nopull
route 192.168.10.0 255.255.255.0
if 192.168.10.0 is the network behind the VPN with a 24bit netmask, the Route-nopull statment should make the client ignore routes (including the default route) which are pushed by the server.
