I just installed Softether on a XEN-Server Virtal Machine (Linux Debian) at my Office
at home I have windows desktop where i installed softether client
my connection at office is 200mbps and at home also 200mpbs
but when I connect to my sofether VPN server, connection is 0,04mbps
I have router at the office, I port-forwarded 5555, 992 ,11194 to my Virtual machine
what is going wrong? there is a very big difference between 200mpbs and 0,04mbps
I created a bridge between virtual hub and eth0, but still not help
How should i configure?
I do need a complex set-up. I just want to connect to my office from home
with kind regards,
Ismet
very very slow connection 0,04 mbps (my connection 200mbps)
isener
Shaike
Re: very very slow connection 0,04 mbps (my connection 200mbps)
Do you use SecureNAT?
Try disable/set "DisableIpRawModeSecureNAT" and "DisableKernelModeSecureNAT" to '1' in Virtual Hub Extended Option.
For me it fixed the issue with download speed rate of 0.04mb/sec
isener
dear Shaike,
thank you for your tip, it helped, it was 0.04mbps now it is betwwen 5mbps and 20mbps
but still not 200mbps
what can I do more??
I have secureNAT enabled
without bridge
without bridge
Shaike
Shaike
Better way with dnsmasq and iptables
https://blog.lincoln.hk/blog/2013/05/17 ... al-bridge/
