WireGuard Protocol
lwk523
WireGuard Protocol
Post by lwk523 » Mon May 16, 2022 4:33 am
Hi ,
Is Softether support wireguard protocol ? If yes, how to setup it ?
Thank you
eddiewu
Re: WireGuard Protocol
Post by eddiewu » Mon May 16, 2022 6:16 am
lwk523
Post by lwk523 » Wed May 18, 2022 12:01 am
Wish next update will capture this feature in GUI
eddiewu
Post by eddiewu » Wed May 18, 2022 1:51 am
There is no plan to implement in GUI unless someone contributes code.
obfusgated
Post by obfusgated » Wed Feb 12, 2025 10:33 am
Here's a guide on configuring WireGuard on a SoftEther server and creating a WireGuard config file. This guide assumes that you already have a build of SoftEther server running in a standalone mode with a properly set virtual hub with at least one user. Ensure the SoftEther build you are using is not from the "stable" branch, as these do not support WireGuard yet.
