Hello everybody,
i need your support. I was interested in using this software and was seeing if it can be useful for my needs.
I have to establish a vpn connection with 5000 and more PCs to reach the website installed on each of these PCs from the server hosting the vpn connection. I have seen that the maximum limit of this software is 4096 connections. Is there a way to establish more perhaps by making multiple instances of the software? or is there a way to connect only when you need to visit the website of a particular PC? The PCs are not controlled by anyone, so it is not possible to manually activate and deactivate the vpn connection.
