Hi
Using Soft Ether Client when i try to connect with a wrong user or password client retry login infinitely
I tryed to remove check "Reconnects automatically after disconnect" but there are NO changes
Client still retry infinitely
Client : Impossible disable auto reconnect
nicola.piazzi
