some question for softether VPN DDNS
chen4u
Hello everyone, I am an IT enthusiast from China. I like to toss with some novel software. Softether VPN is one of them. I have a friend who has a company that operates in different places. I want to use this software to facilitate office work for remote networking. But the early use is still very good, but recently it has been found that the problem of client disconnection often occurs. After inspection, it is found that the IP address of the external network resolved by DDNS will change, and the IP address after the change cannot be pinged on the external network. It is not surprising that the client side found that the virtual HUB could not be found. Is this softether attacked? What is even more strange is that this morning when I tested the same domain name I used, it only took a minute or two before and after the IP address was changed. It has changed, why is this, is there any expert who can give me some pointers, thank you, my email address is chen4u@gmail.com, I hope you can give me your opinion when it is convenient, thank you.
chen4u
Re: some question for softether VPN DDNS
问题找到了,就是softether的DDNS出了问题,使用Azure的域名解析就没有问题了,不知是什么原因引起的DDNS出了故障
