I really hope you guys can help me with this issue I have read the documentation instruction and search online but I cant find the solution for this.
I have configured two servers. One is standalone, and the other is a cluster server of 3 members.
I can connect via vpn to both servers standalone and cluster locally in my network no issues there.
I can aslo connect remotely using OpenVPN from my cellphone to the standalone server, get in my car, and drive to work the connection states state.
I am experiencing issues with the cluster server when trying to connect remotely. Using the softether client on my laptop. The clusters works on local but no matter what I try I cant get it to work from the outsite.
Here is my configuration:
Cluster controller is iP 192.168.4.30 and is set up with a static Hub that is bridge on all member servers network adapter.
Member server A: 192.168.4.31 public IP is set to the same and is connecting to cluster controller successfully
Member server B: 192.168.4.33 public IP is set to the same and is connecting to cluster controller successfully
Member server C: 192.168.4.34 public IP is set to the same and is connecting to cluster controller successfully
Testuser is created at the cluster controller which I tested it locally and it works.
I have port forward 5555 to cluster controller 192.168.4.30 but I still cant connect.
Unable to connect to VPN Cluster from outside network
