I installed VPN server on CentOS VPS and everything seems fine on server side. Then I connected server with SE-VPN Server Manager, set up things. On client side I connected to server with SE VPN Client, both default and Azure Cloud, it seems I successfully connected to server but it doesn't effect, when I checked my ip adress its still showing my own ip adress.
What am I doing wrong?
Operating system name and the type of CPU-bits: Centos 7 x64
Thank you,
regards.
My IP adress not change when connected VPN
raafat
Re: My IP adress not change when connected VPN
Did you get an IP address from DHCP service on SE server ? or how have you set up your settings regarding IP settings ?
Adige
I think I didn't get an IP adress from DHCP service, even I don't know what is it.
I just followed SoftEther Manual from here: https://www.softether.org/4-docs/1-manual and probably I missed that part, could you refer me to related part/settings?
You should create localbridge or turn on SecureNAT.
