SSTP setup
shrm
SSTP setup
Post by shrm » Mon Oct 24, 2022 12:18 am
Hey guys, I just created one VPN server with SoftEther over an Ubuntu. All the steps of setup are done according to the Tutorials provided by the website. I generated a VHub, a certificate, and a user. But I can't run the "SstpEnable yes" command. I got this error:
VPN Server>SstpEnable yes
"SstpEnable": Command not found.
You can use the HELP command to view a list of the available commands.
Within the help nothing about this command, how to activate SSTP on this hub?
kind regards,
Shrm
Re: SSTP setup
Post by solo » Mon Oct 24, 2022 12:51 am
vpncmd localhost:port /server /password:*** /cmd SstpEnable yes
or Win/WINE remote GUI
eddiewu
Re: SSTP setup
Post by eddiewu » Mon Oct 24, 2022 2:15 am
This command has been removed in the developer edition.
https://github.com/SoftEtherVPN/SoftEtherVPN/pull/1177
shrm
Re: SSTP setup
Post by shrm » Mon Oct 24, 2022 6:37 am
Hey Solo, thanks for fast respond, I tried your suggestion:
The result became like this:
root@2dba4b1054aa:/usr/local/vpnserver# vpncmd 107.192.44.129:443 /server /password:MyPass /cmd SstpEnable yes
vpncmd command - SoftEther VPN Command Line Management Utility Developer Edition
SoftEther VPN Command Line Management Utility (vpncmd command)
Developer Edition
Version 5.02 Build 5180   (English)
Compiled 2022/10/22 20:27:54 by  at 2dba4b1054aa
Copyright (c) all contributors on SoftEther VPN project in GitHub.
Copyright (c) Daiyuu Nobori, SoftEther Project at University of Tsukuba, and SoftEther Corporation.
All rights reserved.
Connection has been established with VPN Server "107.192.44.129" (port 443).
You have administrator privileges for the entire VPN Server.
There is no Sstp*** , and regarding the Wine, I am using a Linux server w/o GUI.
shrm
Re: SSTP setup
Post by shrm » Mon Oct 24, 2022 6:38 am
So how can I enable it? Should I pay for that?
eddiewu
Re: SSTP setup
Post by eddiewu » Mon Oct 24, 2022 6:45 am
Read that link, if you read English.
Re: SSTP setup
Post by solo » Mon Oct 24, 2022 6:52 am
Use CLI "edit" and...
	declare ServerConfiguration
		bool DisableSSTPServer true
---> FALSE
shrm
Re: SSTP setup
Post by shrm » Mon Oct 24, 2022 8:34 am
Within the vpn_server.config file, the only line with "SSTP" is:
                       declare SSTP
				bool Enabled true
Should I add this statement?
Re: SSTP setup
Post by solo » Mon Oct 24, 2022 9:59 am
It seems changed in the developer edition. Either use the "ProtoOptionsSet command" which @eddiewu proposed, or run vpnsmgr.exe from Windows or Linux' WINE. You can use SE server manager remotely from another PC/VM with a GUI.
