vpnserver - bug in socket polling
jayjay7000
Post by jayjay7000 » Tue Feb 14, 2023 8:35 am
The vpnserver application, and either l2tp or sstp code, is doing recvfrom() on all open vpn sockets in loop instead of testing with epoll. This causes 100% cpu, specially with many users, since recvfrom just returns etryagain.
This is seen in current stable version and multiple older stable versions
shakibamoshiri
Re: vpnserver - bug in socket polling
Post by shakibamoshiri » Tue Feb 14, 2023 3:25 pm
Have you seen that in DE version ?
Worth mentioning it that has been reported for 5 (DE version) as well :|
https://github.com/SoftEtherVPN/SoftEth ... ssues/1756
jayjay7000
Post by jayjay7000 » Wed Feb 15, 2023 1:18 am
havent tested DE, but I see that several others are having the same issues.
It should be fairly easy to fix for a person familiar with the code.
shakibamoshiri
Post by shakibamoshiri » Wed Feb 15, 2023 6:55 am
You might go and share this on Github.
I think there will be a reason why they have chosen that method.
