Unable to connect via L2TP /Ipsec
veepeeyan
Post by veepeeyan » Tue Feb 21, 2023 7:34 am
I have created an Ubuntu instance with Soft ether vpn installed I successfully connected the vpn via windows client application but I wanted to connect it via my Mac system. So I tried L2TP/IPSEC option to connect but it is not connecting.
I also tried to connect it via windows built in vpn option but it is not able to connect to the server is there any option to configure it or we cannot connect via gcp instance ?
