Connecting to No password VPN Servers
halzi
Post by halzi » Sun Mar 19, 2023 6:30 pm
How do I connect to VPN Servers with no authentication on SoftEther VPN Client Manager?
shakibamoshiri
Re: Connecting to No password VPN Servers
Post by shakibamoshiri » Sun Mar 19, 2023 8:19 pm
you can set the "authentication type" to "anonymous". Then you just need the username.
Note that the client you use should allow your connecting with "empty" password field
