how can i create a client vpn connection with dbus command line and how can i fill the configuration file for vpn client to put the configuration?
there is a tutorial show how can we use softether vpn on ubuntu with command line not a GUI.
and can softether vpn client connect to a openvpn server?
vpn client using dbus api on ubuntu
Re: vpn client using dbus api on ubuntu
Not sure what "dbus" is but you can use "vpncmd" as CLI or using SE manager GUI to create and manager users
Please clarity your question.
If you added a user to an SE server, then you can use that credentials with SE client
No, SE client is for SE protocol
But if you enable OpenVPN server of an SE server, then with OpenVPN client you can connect to the SE server.
- SE client =====> OpenVPN server [ NO ]
- OpenVPN client =====> SE server (if OpenVPN enabled) [ YES ]
