Need Help Softether Vpn Connecting But not opens some sites
fmogaddam
Post by fmogaddam » Wed Apr 05, 2023 10:50 pm
Hi guys i live in Iran as you may know we can't access free world so many sites YouTube Facebook Instagram Twitter and so many other without vpn because dictator regime
i find a way to connect public vpn gate by SoftEther its connecting successfully i can even download file but problem is its not opening every site
for example YouTube but i managed to fix YouTube issue by just adding Google DNS in (Network VPN Client ) not Ethernet Controller (i don't want to use Google DNS in ip4 Ethernet Controller) also Cloud flare DNS not fixing YouTube issue . any way YouTube fixed by Google DNS
now i have same issue on other sites some still not fixed with Google DNS still says took too long to respond or This site can’t be reachedThe connection was reset.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_RESET
do you have any idea how can fix this issue this is more happens on famous censored global sites ?
Thanks
shakibamoshiri
Re: Need Help Softether Vpn Connecting But not opens some sites
Post by shakibamoshiri » Thu Apr 06, 2023 6:31 pm
VPN gate has some public VPN servers and some volunteers sharing their PC/Servers. So it is not 100% reliable if you have been connected to one of those volunteers if they have misconfigured their PC/Servers. Thus
- when you find a working server test it
- use SSTP , others do not work there (Iran)
fmogaddam
Post by fmogaddam » Fri Apr 07, 2023 3:55 pm
Thank You So Much
