You can reach the server with windows gui, wich works with wine on linux.
You do not need third party
GUI for Linux
moatazelmasry
Re: GUI for Linux
Depending on the protocol.
For OpenVPN, L2TP there are some Linux GUI's out there
For SE own VPN protocol, there are non as far as I know
Gene475001
Re: GUI for Linux
I will mention that for L2TP/IPSec you may have some trouble finding a GUI if you want a simple PSK with a password setup in Linux. I managed to get a GUI working with OpenSwan, but it's buggy. I don't think strongSwan (the newest L2TP/IPSec GUI) allows for this, at least I wasn't able to find out how to get it to work.
