I've just installed and configured the SoftEther VPN server. I was able to connect to it via LTP/IpSec and my IP changes according to http://whatismyip.org. If I, however, connect to the same VPN server, running a php script which displays the IP address of the received connection, I get my regular, non-VPN IP address.
Does this mean that the server detects that the client is connecting to a local machine inside the VPN and disables encryption, essentially making the connection visible, if the client is monitored?
I am running the SoftEther VPN server and other services on the same computer and I would rather not expose client connections on the source side.
Any information on this would be fantastic.
Cheers,
Erion
Connection possibly not encrypted with an active VPN session
erion
moatazelmasry
Re: Connection possibly not encrypted with an active VPN ses
Where exactly is this php script running?
erion
Unfortunately I cannot give out web addresses, but any web server that returns an IP address will work.
To reiterate, if the server you are connecting to is also the VPN server, it seems like that the connection is not encrypted, i.e. SoftEther exposes the connecting client. This is sometimes an issue, which, I believe, should be documented.
Erion
Erion
Which client do you use?
Please try to change default gateway IP address to VPN side IP address on VPN client.
